NI TestStand
Trouble with TestStand Core 1 Learning
I am currently making my way through TestStand Core 1 and have reached a small roadblock. Exercise 2-2 requires me to run "Setup.bat" as administrator (from the TS1_2017_EN exercises download included within the course) to install the necessary components in the LabVIEW and LabWindows/CVI. When I run this file, it is failing to install in 2 of the 3 directories:
___________________________________________________________________
* Instrument Simulation Driver installation completed to the following directories:
FAILURE - C:\Program Files\National Instruments\LabVIEW 2020\instr.lib
FAILURE - C:\Program Files (x86)\National Instruments\LabVIEW 2020\instr.lib
Success - C:\Program Files (x86)\National Instruments\Shared\CVI\instr
I'm using LabVIEW 2020 and TestStand 2018.
(949 Views)
Accepted by topic author cmo39
Hi, The bat file basically copies files (VI's) to respective locations in C drive. I don't know the exact root in your system (you can run this bat file in other system if it's an issue in your system only).
I would recommend you to copy those files manually to respective locations shown in your post. This should help you or you can manually update the search files directory to point to your exercises directory in TestStand - as mentioned in the following link https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019WAUSA2&l=en-IN
Dharani | CLA | CTD
(907 Views)
Hi Dharani.R,
Thanks for your quick response! Through a bit more trial and error, I learned that the extension for the folder I had placed my TestStand exercises in was too long for the Setup.bat to handle and that is why it was giving me the failures. I have read through the article you posted and it clarified quite a bit. Thanks for the help!
(898 Views)
