I'm not entirely sure how you're linking to VEE through RPC. I thought Version 6.0 and above of HP VEE is ActiveX????
The best I can find on RPC and vee and timeouts is the following document :
http://ftp.agilent.com/pub/mpusup/pc/vee/veenotes/v23_call.html
There's an api call
* UTILITY FUNCTIONS: Other utility functions in the VEE RPC API include:
long VEEAPI vrpcSetTimeout( VRPC_SERVICE aService,
double aTimeoutInSeconds );
This function allows you to change the timeout. You specify a server handle and the timeout in seconds. You get back a zero if all is OK, and an error code if all is not OK.
Does that help at all?
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer
