NI TestStand
This question is for "teststandtak".Thank you for your answer. I do not know how to co
nnect you. You suggest me to use setvalnumber command to set a value into my 3D array. but in my code i use the getvalnumber command to get a value from the array and do something with it. So I'm looking for a way to fill the array and read it by the code.
(4,054 Views)
nnect you. You suggest me to use setvalnumber command to set a value into my 3D array. but in my code i use the getvalnumber command to get a value from the array and do something with it. So I'm looking for a way to fill the array and read it by the code.You can get the value from the array with the getvalnumber and then use the setvalnumber in the same code to write to the array.
(4,054 Views)
