02-15-2007 04:49 AM
02-16-2007 10:49 AM
09-10-2019 10:01 AM
Even though this post is old, I just had the same issue and want to share some extra details of how I got it solved. The IVI drivers are not installed by default, and must be manually installed. There's a knowledge base article for how to install the IVI drivers, and it instructs you download a very large ISO file, but what it doesn't tell you is that after using 7zip to view the contents, there is a folder called Additional Installation Files where you can install the IVI drivers. Once those are installed, you can set the TestStand version using the selector tool to re-associate the drivers. Note that I had one extra step to perform. I had to use the TestStand version selector to set my installation to 2016, and then back to 2019 before it all actually worked.
