NI TestStand
The report options under “configure” and CSV or xls.
The report options under “configure” does not give .csv or xls as options. Instead of using vi to pass data to database, is there a simple way to transfer all the results (just like the way in the report that automatically generated) to .csv or xls...
Thanks.
(2,647 Views)
in order to modify the report generation, you have to understand the way how TestStand works in regard of the report generation.
There is a tutorial which explains this which you can find here. But please note that the tutorial is currently undergoing an improvement process.
The reason that the report options don't give you the option for xls or csv as report is:
Neither xls nor csv are predefined. So for example measurement values in xls can be placed in a special worksheet or included in a main sheet in a certain column.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,640 Views)
