04-16-2009 03:39 AM
Hello Friends
I m using Teststand .Now only i m start reading for Teststand Please post the easy sequence file with respect to Labview.PLease post ur Vi's with sequence file.
Thanks & Regards
Jayavel
04-16-2009 04:01 AM
04-16-2009 06:42 AM
04-17-2009 12:29 AM
Hello Juergen
I saw that Example Already i need some more Examples how to execute one vi output given to the Another VI s input and some more Examples.
04-17-2009 12:54 AM
Hi Jayavel,
if you take a look at the Computer Motherboard Test Sequence.seq you will see at step Simulation Dialog that the Output results
of the vi were stored in a TS Local Variable (e.g Locals.KeyboardValue).
Now look at step KeyboardTest the TS Varaible Locals.KeyboardValue is a input for this vi.
If you need more Examples you can find at lot of them here on this Topic or at ni.com/support
But if you have understood all the examples that are shipped with TS software then you are even better than our
"Night of Ni-TS" Ray Farmer
Greetings
Juergen
