10-29-2019 05:27 AM
i created a Wrapper dll in c# for a c-dll.
Everything is working and all functions can be called but after 4..10 executions testand stops with big error that says:
Problem signature:
Problem Event Name: BEX
Application Name: SeqEdit.exe
Application Version: 14.0.0.274
Application Timestamp: 53ace5da
Fault Module Name: clr.dll
Fault Module Version: 4.8.4018.0
Fault Module Timestamp: 5d4a64a8
Exception Offset: 0035a3f8
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2055
Additional Information 1: 6f94
Additional Information 2: 6f94982914938ac345e05a421091cbf5
Additional Information 3: 73c3
Additional Information 4: 73c346c7bd00900375bf67b1a9847619
What can i do to avoid this?
I am using TestStand 2014
The C# dll is compiled using .NET Framework 4.6.1
Thanks for help
03-23-2021 12:40 PM
Hello, Iknow that this post is old, but I have a similar problem,: did you find a solution?
Thanks in advance
03-23-2021 03:44 PM
Hm, yes i found a solution but i cannot tell currently what i changed...
