01-31-2019 03:26 AM
I am trying to make an deployment which contains some folders target to be installed to C:\Program Files. Even though I selected Windows Volume C: as Installation Destination and Program Files as Installation Destination Subdirectory. It always install the folders to C:\Program Files (x86) on target machine. The Teststand version I am using is 2017(32-bit).
Any idea on that?
Thanks a lot!
Br,
Yan
01-31-2019 03:46 AM
32-bit applications should be installed to the x86 folder. That is correct behavior.
01-31-2019 06:43 AM
Maybe some misunderstanding here. I am making a deployment with Teststand. Not installing Teststand itself. When I want to deploy folders under C:\Program Files, how can I implement it with Teststand Development Utility?
Yan
02-07-2019 05:34 AM
If I understood your problem correctly, if the operating system is 64-bit, they will get installed in the Program Files (x86) directory.
See the article below:
https://zone.ni.com/reference/en-XX/help/370052W-01/tsfundamentals/infotopics/64deployinstallers/
Hope it helps.
Cheers,
Rob
