NI TestStand
Teststand and labview testing corrupting USB (error43 in Device Manager)
Hello everyone,
I have a question. I hope this is in the right forum.
At my work we have a automated testcase. We have some Teststand sequences which test the UUT automatically. Sometimes when we are testing, an USB driver stops working (error43 in Device Manager) and we need to shutdown Teststand and LabVIEW, disable the USB device, enable it, and start everything up again.
-I already updated every driver possible and every program on the pc.
-I also looked online, donwloaded some tools to scan the pc for broken and/or corrupted drivers, nothing found.
-I also disabled selective suspending and unchecked the box for disabling usb's to save power.
Anyone had the same issue or something related to it?
System is a Windows 10 with Teststand 16 and LabVIEW 15.
Failing organizations are usually over-managed and under-led.
(2,612 Views)
To anyone with this issue: in my case, the error of migrating USB went hand in hand with Error43. The problem is faulty Windows10 code. Since August 2015 many people had the issue of migrating USB not working and thus Error43. A solution is or use a different Windows, or uninstall some updates, starting with the newest ones.
I hope this helps someone.
(2,444 Views)
