I am trying to work in TesStand using LabVIEW 2012 32 bit. I downloaded TestStand 2014 with is listed as being compatable with my version of LabVIEW. However it gives the following error when I try to insert a VI from LabVIEW "LabVIEW version 12.0 is not installed"
I looked into this and since I have LabVIEW 32 bit I saw that I would need to adjust the configuration in the configuration tab. I went to configure, adapters, and then I clicked "Configure" with LabVIEW selected. I checked the "LabVIEW Development System" and then went to "Use Active 32-bit Version: 2012 SP1 f5 (12.0.1) - Not Allowed" (This not allowed was my first hint that this might not work...).
When I select this anyway it comes up with an error
"Test Stand (64-bit) requires LabVIEW 2013 SP1 or later.
LabVIEW 2012 (12.0.1f5) is currently active.
Test stand cannot connect to LabVIEW.
Error Code: -18001, An error occurred accessing the LabVIEW ActiveX automation server."
I am not sure what to do. I orriginally installed TestStand 16 which gave the same errors, however I am confused with this is still happening in TestStand 2014.
Any ideas or help that you can give me would be great!
Thanks!
