02-28-2023 01:06 AM
Hello
I have two computers that running Test on Testunits.
One of them also takes over the control of your climate chamber and the reading of the serial numbers.
Now I have to pass these numbers on to the second computer.
The computers are connected to each other via Ethernet.
Is this possible with the board resources from Teststand?
03-01-2023 05:38 AM
Hi Chris2000,
You can transfer files from a development computer to a test station computer by using distribution media, by copying files from a local network, or by using email or FTP, depending on the location of the test station computers and available resources.
For more information, please follow this link.
Regards)
03-08-2023 12:20 AM
Is it possible to use FTP or Email with only Teststand.
I know i use Shared Variables with Labview but in the current situation i have only Teststand
03-08-2023 01:08 AM
Hi Chris2000,
To my knowledge, yes, you can use FTP file transfer step without using LabVIEW. For email transferring there is no such information about that I have found, and I didn't try that yet. Try to test it in your side by using FTP file transfer step.
Regards)
03-08-2023 10:38 PM
If you have TestStand on both the machines, you can use Synchronization objects to send the data between machines.
Quote from the following link - "You can also create a Synchronization object on a specific computer by beginning the name of the object with the computer name, such as \computername\syncobjectname, which you can use to access the Synchronization object from any computer on the network. "
Name - Common Attributes of Synchronization Objects - NI
Also see - Setting Up TestStand for Accessing Synchronization Objects Remotely - NI
Anand Jain
NI
03-17-2023 01:35 AM
is there an example for the use.
Because if i try to use it, i get an Syntax error.
03-17-2023 10:12 AM
More information about how to configure the name - Name - Common Attributes of Synchronization Objects - NI
Anand Jain
NI
