06-11-2007 04:02 AM
06-13-2007 04:51 AM
Hi there,
If you go into the vi properties there should be an option under Execution that defines the "preferred execution system". this needs to be "same as caller" to achieve what you are looking for.
Beyond that, you shouldn't have a problem with the global variables, but if you still do I would suggest that you pass all the variables you need into TestStand and define a number of global variables in there that will pass values to and from the vi's you call. Might be a little easier to debug also.
Hope this helps
AdamB
