11-26-2019 09:11 AM
Hi all,
I'm trying to integrate our VIs and sequences (these are a lot) into a build I am creating with the Teststand Deployment Utility.
Some older files I removed as they shouldn't be needed anymore (e.g. in user-created "backup" or "trash" folders), but there seem to be quite some references to these files, as the Deployment Utility tries to locate them.
Now I cannot find the origin of these dependencies as the utility only shows the path to the file it cannot find, but not the origin.
Is there a way to make the utility show which VI or sequence file is referencing the removed files?
Any hint or help appreciated.
11-27-2019 12:10 AM
Hold on - I found it.
The "Additional Details" section can be minimized and looks like this:
When clicking the marked arrow it expands and shows the caller (including path):
