NI TestStand
Teststand Current Active Version over command line
Highlighted
is there a way to retrieve the current active version of TS over a command-line interface of Teststand Version Selector?
The Version Selector's API has an argument /version, which is used solely for switching...
Thanks in Advance,
Roman
(1,876 Views)
Highlighted
Type Set TestStand
It will tell you the current TestStand Dir.  That should be your active version.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,873 Views)
Highlighted
If any of you confused about @jigg response. SET TestStand
Ajay
(162 Views)
