Teststand Current Active Version over command line
is there a way to retrieve the current active version of TS over a command-line interface of Teststand Version Selector?
The Version Selector's API has an argument /version, which is used solely for switching...
Thanks in Advance,
Roman
(3,297 Views)
Type Set TestStand
It will tell you the current TestStand Dir.  That should be your active version.
jigg
CTA, CLA
testeract.com
(3,294 Views)
If any of you confused about @jigg response. SET TestStand
Ajay
Ajay MV
(1,583 Views)
