09-29-2008 03:48 AM - edited 09-29-2008 03:50 AM
have passed the Sequence Conetext (ThisContext) from Teststand to my C#-Dll (VS Studio 2005).
In the DLL I want to walk through the Sequence Context item by item (like the tree view in the Context tab of the sequence editor).
My idea was to ask the sequence context how many elements are existing in each level and then address each item by an index and ask for its type and do further processing.
(If it is an container, just ask how many items are contained and so on...)
I have tried this approach:
static public void MyFunc(ref SequenceContext MySequenceContext){
int Index;string lb, ub;
PropertyValueTypes type; int NumOfSubproperties;MySequenceContext.AsPropertyObject().GetDimensions("", 0, out lb, out ub, out NumOfSubproperties, out type);
but I'm immediately getting this error:
Exception has been thrown by the target of an invocation.
Root Exception:Specified value does not have the expected type.
Source: at NationalInstruments.TestStand.Interop.API.PropertyObject.GetDimensions(String lookupString, Int32 options, String& lowerBounds, String& upperBounds, Int32& numElements, PropertyValueTypes& elementType)
at xxx.yyy.MyFunc(SequenceContext& MySequenceContext) in C:\\yalayalayala\\xxx.cs:line 38 [Error Code: -17500, Operation Failed.]
I alternatively tried this
int Index;
string lb, ub; PropertyValueTypes type;int NumOfSubproperties;
NumOfSubproperties = MySequenceContext.AsPropertyObject().GetNumElements();
This time the error was:
Source: at NationalInstruments.TestStand.Interop.API.PropertyObject.GetNumElements()
Isn't it possible to ask for each object, how many elements it has?
Many thanks
Thorsten
Sorry, I forgot to mention, that I'm using Teststand 3.1...
09-29-2008 10:10 AM
The Sequence Context is a container, not an Array. The functions you are trying to use are meant for objects that are Arrays.
You should instead use the following function:
PropertyObject.GetNumSubProperties.
To access each individual subproperty, you can use the following functions:
PropertyObject.GetNthSubProperty
and
PropertyObject.GetNthSubPropertyName
Allen P.
NI
