Howdy all,
I have Teststand 2019 installed on the development workstation and on the test workstation. For this issue, here are the known data:
1. Sequence file used on both workstations - dev and test -- is identical.
2. Configure -> Result Processing -> Report -> Options are identical with the exception of final location (e.g. "$(ClientFileDir)…" vs "F:\\FooData")
Now with these
On the development workstation, I'm able to generate PDF reports (via Configure -> Result Processing -> Report -> Options, checkmark Generate PDF Report). On the test workstation, the same sequence file does not generate PDF reports even when the Generate PDF Report is checked in Config->Result Processing.
Why?
I've already compared the configuration settings for everything - side by side (development workstation is actually a laptop so I could do that with the test workstation which is a desktop) - and all looked the same. Is there somewhere else that I may have missed checking?
Thanks!
