I have created sequence file and it worked fine. After creating custom data type of Labview (cluster with coupple of enums inside) it appears that TS has problems with it. The TS Sequence editor crashes everytime that I insert value of parameter inside of any step.
I'm searching for any suggestions what can I possible try to fix this? Crashes are not present in other sequence files when I edit them. There is also not any error thrown when Sequence Editor is hanged. Also there is not any error described of displayed when I open TS again.
