05-12-2021 05:44 PM
TestStand 2017 32-Bit
Windows 7, Windows 10
We just started converting some testers over to Windows 10 and noticed that the UUT Dialog changes when running in Windows 10. As you can see in the pictures, it no longer displays all 8 sockets. In Windows 10 you must grab the mouse and scroll down to to see the bottom 3 sockets, (whereas Windows 7 displays all 8 sockets without scrolling). It is also impossible to resize the inner box in Windows 10. The entire dialog will resize, but the display of the sockets remains the same size.
I am hoping that someone can tell me what settings I can change to allow all 8 sockets to be displayed as they were under Windows 7.
Thanks very much,
Solved! Go to Solution.
05-17-2021 04:58 AM
Hi, I checked on my side too. What you are seeing is expected. Looking the screenshot, it is customized UUT dialog box. If you are the developer, you can customize this dialog box to display all 8 at once. I hope this helps.
05-17-2021 05:44 PM
Thanks for the reply. None of the original developers are here any longer. I am not sure if the Dialog was customized or not (what made you say that it is?), regardless, I will look into changing it. That is probably my only solution.
When I say that I am not certain it is customized - if I do a clean install of teststand on a new machine, I get the same dialog.
Thanks again.
05-18-2021 02:25 AM - edited 05-18-2021 02:27 AM
HI, I am attaching 2019 (left), 2020 (right) TS UUT dialog-box here for your reference. If you observe carefully, the shipping ones does not have Ok & Stop buttons hence I believe is a customized dialog-box.
05-19-2021 12:03 PM
Thank you. This is very clearly different than mine. BTW, mine is the parallel dialog. Is this also?
05-20-2021 12:08 AM - edited 05-20-2021 12:11 AM
Oh Sorry. I am using Batch process model. For parallel, it looks same as it is expected behavior.
However, I customized it for you to display all 8 at once. I am attaching same with this post. You will have to replace the dll called modelsupport2.dll in the following directory:
I hope this helps.
Dharani | CLA | CTD
05-20-2021 10:22 AM
Yes Dharani, We are using 32 Bit. If you do not mind that would be awesome.
(I cannot believe that you are willing to do this) Thanks so much!
Is it possible for you to give a quick outline of what was needed to modify this?
Thanks again,
05-20-2021 10:44 AM - edited 05-20-2021 10:48 AM
Hi, Please find a copy of 32 bit dll. I was referring to this NI KB - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHmUCAW&l=en-IN
Since I had LabWindows CVI installed on my system, I could test the same at my end before sharing it with you 🙂
Do let me know if it working for you or not.
Dharani | CLA | CTD
05-20-2021 03:11 PM
Hi Dharani,
Thanks again, Unfortunately this will not load. I am using Windows 10 Version 1909 OS Build 18363.1500
I get the following error messages from Teststand. I will attempt to build this myself. I do appreciate your assistance but I fear I cannot ask you to do more to resolve this.
Errors:
Details:
Could not load DLL or external library 'C:\Program Files (x86)\National Instruments\TestStand 2020\Components\Models\TestStandModels\modelsupport2\modelsupport2.dll'.
This DLL requires the following DLLs which could not be found or loaded:
api-ms-win-core-libraryloader-l1-2-0.dll (Not Found)
api-ms-win-core-heap-l2-1-0.dll (Not Found)
api-ms-win-gdi-internal-uap-l1-1-0.dll (Not Found)
api-ms-win-core-delayload-l1-1-1.dll (Not Found)
api-ms-win-core-delayload-l1-1-0.dll (Not Found)
api-ms-win-core-apiquery-l1-1-0.dll (Not Found)
api-ms-win-core-rtlsupport-l1-2-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-3.dll (Not Found)
api-ms-win-core-processthreads-l1-1-2.dll (Not Found)
api-ms-win-core-registry-l1-1-0.dll (Not Found)
api-ms-win-core-memory-l1-1-1.dll (Not Found)
api-ms-win-core-memory-l1-1-2.dll (Not Found)
api-ms-win-core-synch-l1-2-1.dll (Not Found)
api-ms-win-core-file-l1-2-2.dll (Not Found)
api-ms-win-core-file-l1-2-1.dll (Not Found)
api-ms-win-core-io-l1-1-0.dll (Not Found)
api-ms-win-core-io-l1-1-1.dll (Not Found)
api-ms-win-core-job-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-private-l1-1-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-2.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-1.dll (Not Found)
api-ms-win-core-libraryloader-l2-1-0.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-2.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-1.dll (Not Found)
api-ms-win-core-datetime-l1-1-1.dll (Not Found)
api-ms-win-core-datetime-l1-1-2.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-0.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-3.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-1.dll (Not Found)
api-ms-win-core-localization-private-l1-1-0.dll (Not Found)
api-ms-win-core-processsnapshot-l1-1-0.dll (Not Found)
api-ms-win-core-processenvironment-l1-2-0.dll (Not Found)
api-ms-win-core-debug-l1-1-1.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-3.dll (Not Found)
api-ms-win-core-fibers-l1-1-0.dll (Not Found)
api-ms-win-security-base-l1-1-0.dll (Not Found)
api-ms-win-security-base-l1-2-0.dll (Not Found)
api-ms-win-core-comm-l1-1-0.dll (Not Found)
api-ms-win-core-wow64-l1-1-1.dll (Not Found)
api-ms-win-core-wow64-l1-1-0.dll (Not Found)
api-ms-win-core-realtime-l1-1-0.dll (Not Found)
api-ms-win-core-systemtopology-l1-1-1.dll (Not Found)
api-ms-win-core-systemtopology-l1-1-0.dll (Not Found)
api-ms-win-core-processtopology-l1-1-0.dll (Not Found)
api-ms-win-core-namespace-l1-1-0.dll (Not Found)
api-ms-win-core-file-l2-1-2.dll (Not Found)
api-ms-win-core-file-l2-1-3.dll (Not Found)
api-ms-win-core-file-l2-1-1.dll (Not Found)
api-ms-win-core-xstate-l2-1-0.dll (Not Found)
api-ms-win-core-xstate-l2-1-1.dll (Not Found)
api-ms-win-core-localization-l2-1-0.dll (Not Found)
api-ms-win-core-normalization-l1-1-0.dll (Not Found)
api-ms-win-core-fibers-l2-1-0.dll (Not Found)
api-ms-win-core-fibers-l2-1-1.dll (Not Found)
api-ms-win-core-sidebyside-l1-1-0.dll (Not Found)
api-ms-win-core-appcompat-l1-1-0.dll (Not Found)
api-ms-win-core-appcompat-l1-1-1.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-0.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-1.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-2.dll (Not Found)
api-ms-win-core-console-l1-2-1.dll (Not Found)
api-ms-win-core-console-l2-1-0.dll (Not Found)
api-ms-win-core-console-l2-2-0.dll (Not Found)
api-ms-win-core-console-l3-2-0.dll (Not Found)
api-ms-win-core-psapi-l1-1-0.dll (Not Found)
api-ms-win-core-psapi-ansi-l1-1-0.dll (Not Found)
api-ms-win-security-appcontainer-l1-1-0.dll (Not Found)
api-ms-win-core-winrt-string-l1-1-0.dll (Not Found)
api-ms-win-core-winrt-l1-1-0.dll (Not Found)
api-ms-win-appmodel-runtime-l1-1-0.dll (Not Found)
api-ms-win-core-string-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-shlwapi-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-l1-2-0.dll (Not Found)
api-ms-win-core-localization-obsolete-l1-2-0.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-2.dll (Not Found)
api-ms-win-core-heap-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-crt-l1-1-0.dll (Not Found)
api-ms-win-core-crt-l2-1-0.dll (Not Found)
api-ms-win-security-lsalookup-l1-1-0.dll (Not Found)
api-ms-win-security-lsapolicy-l1-1-0.dll (Not Found)
api-ms-win-core-fibers-l1-1-1.dll (Not Found)
api-ms-win-core-privateprofile-l1-1-0.dll (Not Found)
api-ms-win-core-quirks-l1-1-0.dll (Not Found)
api-ms-win-core-path-l1-1-0.dll (Not Found)
api-ms-win-core-shlwapi-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-com-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-0.dll (Not Found)
api-ms-win-shcore-taskpool-l1-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-0.dll (Not Found)
api-ms-win-core-winrt-error-l1-1-0.dll (Not Found)
api-ms-win-shcore-sysinfo-l1-1-0.dll (Not Found)
api-ms-win-security-sddl-l1-1-0.dll (Not Found)
api-ms-win-core-com-midlproxystub-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-0.dll (Not Found)
api-ms-win-eventing-classicprovider-l1-1-0.dll (Not Found)
api-ms-win-core-registry-l1-1-1.dll (Not Found)
api-ms-win-security-activedirectoryclient-l1-1-0.dll (Not Found)
api-ms-win-devices-config-l1-1-1.dll (Not Found)
api-ms-win-core-stringansi-l1-1-0.dll (Not Found)
api-ms-win-mm-time-l1-1-0.dll (Not Found)
api-ms-win-mm-mme-l1-1-0.dll (Not Found)
api-ms-win-mm-misc-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-2.dll (Not Found)
api-ms-win-core-memory-l1-1-3.dll (Not Found)
api-ms-win-core-atoms-l1-1-0.dll (Not Found)
api-ms-win-core-appinit-l1-1-0.dll (Not Found)
api-ms-win-core-com-private-l1-1-0.dll (Not Found)
api-ms-win-core-com-private-l1-3-0.dll (Not Found)
api-ms-win-core-com-private-l1-1-1.dll (Not Found)
api-ms-win-eventlog-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-registry-l2-1-0.dll (Not Found)
api-ms-win-core-psm-key-l1-1-0.dll (Not Found)
api-ms-win-service-management-l1-1-0.dll (Not Found)
api-ms-win-service-winsvc-l1-1-0.dll (Not Found)
api-ms-win-core-com-private-l1-2-0.dll (Not Found)
api-ms-win-eventing-consumer-l1-1-0.dll (Not Found)
api-ms-win-eventing-consumer-l1-1-1.dll (Not Found)
api-ms-win-service-core-l1-1-0.dll (Not Found)
api-ms-win-service-core-l1-1-1.dll (Not Found)
api-ms-win-service-core-l1-1-2.dll (Not Found)
api-ms-win-service-management-l2-1-0.dll (Not Found)
api-ms-win-service-private-l1-1-4.dll (Not Found)
api-ms-win-service-private-l1-1-2.dll (Not Found)
api-ms-win-service-private-l1-1-3.dll (Not Found)
api-ms-win-service-private-l1-1-0.dll (Not Found)
api-ms-win-security-base-private-l1-1-0.dll (Not Found)
api-ms-win-core-registry-l1-1-2.dll (Not Found)
api-ms-win-security-audit-l1-1-1.dll (Not Found)
api-ms-win-security-audit-l1-1-0.dll (Not Found)
api-ms-win-core-perfcounters-l1-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-1.dll (Not Found)
api-ms-win-core-localization-l1-2-2.dll (Not Found)
api-ms-win-core-version-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-1.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-2.dll (Not Found)
api-ms-win-core-url-l1-1-0.dll (Not Found)
api-ms-win-core-registryuserspecific-l1-1-0.dll (Not Found)
api-ms-win-shcore-path-l1-1-0.dll (Not Found)
api-ms-win-storage-exports-internal-l1-1-0.dll (Not Found)
api-ms-win-storage-exports-external-l1-1-0.dll (Not Found)
api-ms-win-shell-shellcom-l1-1-0.dll (Not Found)
api-ms-win-shell-shellfolders-l1-1-0.dll (Not Found)
api-ms-win-stateseparation-helpers-l1-1-0.dll (Not Found)
api-ms-win-security-capability-l1-1-0.dll (Not Found)
api-ms-win-core-job-l2-1-0.dll (Not Found)
api-ms-win-security-cryptoapi-l1-1-0.dll (Not Found)
api-ms-win-core-versionansi-l1-1-0.dll (Not Found)
Error Code:
-17004; Could not load DLL or library.
Step 'Read Model Option Defaults' of sequence 'Initialize Execution Entry Point' in 'ModelSupport.seq'. Test Socket -1.
05-20-2021 09:56 PM - edited 05-20-2021 09:57 PM
Hi, looks like many dependencies are missing (it will take time to debug and fix). My suggestion is to customize the source code by using NI LabWindows CVI. You can uninstall it after customizing it.
You just need to open the project modelsupport2.prj >> paralleluutdlg.c >> update MAX_NUM_TEST_SOCKETS_VISIBLE 8 (as shown below) >> Rebuild the project by running the project.
Dharani | CLA | CTD
