03-04-2012 09:26 PM
Hi, everyone.
Today I have installed the Teststand 2010 SP1 eval version on Windows XP but an error pops up when I run the sequence editor, as per shown in the attached screenshot.
Hopefully, someone can help and advise me on this.
Thanks.
03-05-2012 02:19 AM
Make sure you have Service Pack 3 installed for Windows XP.
03-06-2012 12:05 AM
thanks.
But my PC is installed with Windows XP SP3.
03-06-2012 10:36 AM
When you run the TestStand Version Selector, do you get any errors?
Jim
03-06-2012 09:00 PM
Yes, there is an error.
Please refer to the attached picture.
When I tried to make active of Teststand 2010 SP1, there is also an error.
03-07-2012 01:10 PM
I've never seen those errors - maybe somebody else has and can give better advice.
I'd try doing a repair operation from 'Add or Remove Programs'. If that doesn't work then doing an un-install and re-install should fix it.
It does look like the installer couldn't access the registry the first time. I'd disable virus scan and Microsoft updates before trying a second time and check that the installer is run in an 'Administrator' account.
Jim
03-07-2012 04:15 PM
Make sure you reboot when it prompts you after the install. I've seen weird stuff like this happen if I try to open TS and I've neglected to reboot the PC after installing.
06-13-2012 11:50 AM
Hi uoi,
I have created a Knowledge Base article which addresses the issue described in this thread. Hopefully, you have long since found a solution for your issue but I wanted to leave this here for anyone that may run into it in the future.
