NI TestStand
Testsocket index of a new Execution: how to get the Testsocket index of the caller
I need to get the Testsocket Index inside of a called Sequence (called as new execution with the sequential model). It seems that this variable: RunState.Testsocket.MyIndex is filled in this case with 0 and the count with 1. In the calling sequence these values are filled correctly.
I also tested it with the parallel model (and the same sequence)  and the result was 4 new executions, so instead of 4, I now have 4x4 🙂 .....
If I do not use a process modell the reporting is not triggered (at least that's my understanding).
Is there any way how to get the testsocket index of the caller (like RunState.Engine.....caller.getTestsocket.MyIndex()  ??)
Otherwise I need to work with parameters and this means a complete new approach (different Syntax, different way to meassure execution time, etc...)
Thanks for your Help
Best Regards
Matthias
(2,346 Views)
Accepted by topic author run321
Hi Matthias,
When you call a step in a new execution, you can store back an object reference to the new execution:
So, you first create a variable of type Object Reference to hold this reference. Then, in the post expression for the sequence call, you can attach a new attribute to the execution object that contains the caller's socket index. In order for this to work, you have to explicitly cast the new execution object to a Property Object.
Then, just use an expression to fetch that attribute into a convenient variable inside the new execution (again, you need to explicitly cast to a property object here to leverage the attributes).
You can find a simple example that just reports out the parent socket in a message popup attached to this post.
(2,297 Views)
