04-05-2021 05:45 AM
Anybody came across TestStand run-time error code of -2147483648 and what is means?
04-05-2021 10:56 AM
It not a TS error but rather one generated by your user program and occurred in the step "Init_SWCTRL" with the error message "AG34980A Failed Initialization"
So, in simple terms, your instrument 34980A Multifunction Switch could not be initialized.
If you're the developer, would recommend looking at why the instrument fails init.
If you're a user, please reach out to the support team or developer of the test program for further debugging.
In some cases, it could be as simple as loose cabling between the instrument and the system, reset the instrument or restart the system.
11-11-2021 09:52 AM
I'm getting this error, when I upgrade my system to Windows 10 OS. It works fine with Windows 7.
