01-06-2012 07:15 AM
01-06-2012 09:42 AM
After you make the change to the teststand type, you need to open the properties dialog on the type and update the cluster passing settings for the newly added property. Are you doing this and it's still not working?
-Doug
01-06-2012 11:29 AM
As myself and Doug have mentioned, you need to go to the Type properties (right click on the type, select Properties) and change the Cluster Passing label field in the typedef to match the label of the field in the LabVIEW typedef.
For example, if you have added a new numeric called 'Voltage' to your LabVIEW tyepdef, you'll need to add a numeric to your TS typedef (can be called anything, suppose you name it 'Foo' for this example), then go to the properties of the type, Cluster Passing tab, select 'Foo' in the Property dropdown and enter 'Voltage' for the Cluster Item Label. This tells TS how to map the fields of the container to the fields of the LV typedef.
01-07-2012 11:18 AM
That fixed it guys! Wish I would have known that a few days ago, would have saved me an hour or so of work.
05-18-2012 08:29 AM
Everyone,
Please vote for the following feature request:
This is something that is long overdue and would be a great addition to the TestStand product.
