NI TestStand
TestStand sequence launchs Labview Window
I create a dummy sequence on both systems and then I tested each one on the other system.
Unfortunately, the behaviour is the same. On the master bench, no labview window is launched when TestStand opens a sequence.
Moreover, I monitor the process activation with Windows Task Manager and on the master bench (where labview windows isn't opened) TestStand launchs Labview.exe.
So, labview.exe is present in memory, the adapter is Development System 7.1 but no labview window is opened.
Can anyone explain this behaviour?
Regards
Message 11 of 12
(1,530 Views)
Accepted by topic author Michele74
The solution:
In the labview.ini sets the following item
HideRootWindow=True
In this way, also using the development environment, TestStand doesn't launch any Labview windows
Message 12 of 12
(1,488 Views)
