‎05-06-2026 03:44 AM
Hi everyone,
I am encountering an issue using a .lvlibp with TestStand 2016 and LabVIEW 2017 (32-bit)
When I configure the TestStand LabVIEW Adapter to use the LabVIEW Development System, everything works as expected. However, as soon as I switch the adapter to use the LabVIEW Run-Time Engine, I have error code -17600 in the sequence.
When I open the sequence, I notice LabVIEW starts loading several VIs into memory, and the sequence is ok
Thanks in advance for your help
‎05-06-2026 03:58 AM
Error -17600 in TestStand Using the LabVIEW Run-Time Engine
‎05-06-2026 04:19 AM
As in the referenced KB, there are multiple reasons.
Can you check the following:
- which LV version has been used for creating the lvlibp
- which OS has been used to create the lvlibp
You might want to test checking the "Enable Version Independent Runtime Engine"
Yet I have seen instabilities whne using this.
