09-10-2008 12:46 AM
is there a chance to print documentations in TestStand, like the VI - documentation in LabVIEW (File => Print => Select VI => VI Documentation) ?
Patrick
Solved! Go to Solution.
09-10-2008 04:53 AM
Hi Patrick,
do you mean the documentation you wrote in your sequence file?
As far as I know you can't print it out
09-10-2008 05:35 AM
There is a documentation tool under the Tools menu item (Tools | Sequence File Documentation ...) This will bring up a dialog so you can select what you items will be put in the document.
Hope this helps
Regards
Ray Farmer
09-10-2008 07:51 AM
Great, haven't noticed that before...
09-10-2008 01:02 PM
gedi,
If you are using TestStand 4.0 or 4.1, you can save your sequence files in XML format and use the Sequence File Viewer to see or print them without the TestStand engine.
The Sequence File Viewer is available as part of the NI TestStand Toolkit for Large Application Development from NI Labs.
