04-06-2009 12:23 PM - edited 04-06-2009 12:24 PM
I'm trying to do the following in TestStand :
I'm trying to do a new thread withing a sequence that will catch .net events from a code module. This new thread will indicate or stop the execution of the main thread. Anyone has any idea how we can achieve this or any example using the TestStand API or something else ?
04-08-2009 01:30 PM
Hi Crusader,
To communicate between two instances of .NET code modules, you can use a process called .NET Remoting. This is explained at this DevZone document here: http://zone.ni.com/devzone/cda/epd/p/id/6064 . This document has an example of communicating between TestStand and LabVIEW using .NET, but the same principles can be applied for communicating between two instances of your .NET code in your TestStand sequence.
04-08-2009 01:49 PM
Hi Eric,
I don't think that .NET remoting could help in this case. If it can, how will I be able to catch the events coming from the remote object within TestStand ?
04-08-2009 05:13 PM
Here is a good example of someone creating an event in one program and handling it in another program: http://www.codeproject.com/KB/IP/remotingandevents.aspx
The author of this page has a few different approaches, but the first seems the most straightforward. You can download the code and check it out to see exactly how he does it.
04-08-2009 05:29 PM
04-09-2009 07:26 AM
yeah I would like to terminate the execution of the main sequence when I received an Events from .NET.
One part of this project would be to stop the execution of the main sequence in the monitoring thread.
Do you have any example of this, I've try passing the Execution has a parameter to my monitoring sequence, but it didn' t seem to work.
04-09-2009 09:49 AM
