NI TestStand
TestStand Warning Message when closing after running TSM sequence
I'm getting below warning message when I close TestStand after running one TSM sequence.
What could cause this problem?
References to PropertyObjects were not released properly.
Total number of objects: 102
Number of top-level objects: 5
Note: Some top-level objects may be included if they are referenced by
an incorrectly released top-level object. For example, an unreleased
SequenceContext object references a SequenceFile object.
The following top-level objects were not released:
Type Definitions [4 object(s) not released]
Type Definition #1:
Type Definition #2:
Type Definition #3:
Type Definition #4:
PropertyObjects [1 object(s) not released]
PropertyObject #1:
Type: NI_SemiconductorModule_StationSettings
(2,936 Views)
Accepted by topic author AustinHong
This means a reference to an object was left open. Do you override the GetStationSettings Callback?
TestStand: PropertyObjects Were Not Released Warning When Using LabVIEW Code Module
-Trent
https://www.linkedin.com/in/trentweaver
(2,910 Views)
I verfied it isn't a severe memory leak by memory profiling.
And I can disable the popup in TestStand by unchecking “Report Object Leaks” under ‘Configure » Station Options » Preferences » Debug Options’.
(2,882 Views)
