05-30-2017 02:48 PM
Dear TestStand community,
recently I've faced the following problem. I install TestStand 2016 (32 and 64 bits, both) on Windows 7, SP1. Installation goes smooth, but after restart of PC, I get the message that "... mfc140.dll is missing".
When I start TestStand Sequence Editor, then I recevie message "TestStand 2016 (16.0.0.185) must be active version of TestStand to use the Sequence Editor". When I start TS Version Selector, I get message that mfc140.dll is missing.
Reinstall does not help. The situation is similar for 32 and 64 bits versions.
Also, I installed separately (from distribution folder) TS Tool (like repair of the installation). It didn't help.
Could anyone, please, help me with this issue and suggest, what can cause it?
Thanks a lot in advance!
Sincerely, kosist90
Check out new feature of LabVIEW 2017!
05-31-2017 11:58 AM
Hi Kosist90,
In doing some research, I found that a similar issue was resolved by downloading the Visual C++ Redistributable for Visual Studio 2015 here:
https://www.microsoft.com/en-us/download/details.aspx?id=48145
This was based on a forum post seen here:
Please let me know if this resolves your issue.
05-31-2017 01:45 PM
Amazing, now it's working! Actually I had installed Visual C++ Redistributable for Visual Studio 2015, but it seems that it had some issue - I uninstalled it; installed the one from those links what you've provided, and everything is fine now.
Thanks a lot, Mada_17!
05-31-2017 01:47 PM
That's great news! Thanks for letting me know. Best of luck!
04-26-2018 10:27 AM - edited 04-26-2018 10:31 AM
It might be worth noting that you need to install the version (32bit or 64bit) of .Net corresponding to the version of Teststand you have installed NOT your operating system.
