NI TestStand
TestStand UI not showing test sequence during execution
Hello friends,
I am observing a seemingly odd behaviour where right after triggering my test execution TS goes into a state where I cannot see my test sequence getting executed.
What else is gone?
- Step settings shows no step is selected.
- Variable pane is empty.
I checked the call stack to see if it was stuck somewhere while switching but that too is blank.
Meanwhile, my execution is ongoing and if I'd inserted a breakpoint, it'll break at that step and everything would start to be visible again.
PFA, runtime image.
Would really appreciate your help.
Cheers,
Samarth
(672 Views)
Accepted by topic author SamarthKansal
I guess you can try to checking if the "Enable Tracing" option is checked in the "Execution" tab page of the interface popped up by selecting Menu : Configure --> Station Options.
(652 Views)
Hello Andrew,
Thank you for your suggestion. It worked!
(633 Views)
