In TestStand SetUP Tab, I have a VI findingserialport; either COM1 or 2; then I am using VISA to set the baud rate of either COM1 or 2. The VISA property node return a VISA Resource Name, I like to store the VISA Resource Name as a TestStand locals, or Station Global for used by the VIs in the Main Tab.
What TestStand Set property Value may I use? the Object does not work. Is it a numeral type?
