01-18-2021 02:20 AM
Hi Everyone,
I have a TestStand sequence. One of the VIs is built on dLL files. I have a problem with looping as the program hang somewhere and either continue working very slowly or exit without completion.
The For Loop is part of TesStand sequence and VI is inside the sequence.
I tried to make the loop inside LabVIEW but it is much worse case where the program hangs earlier (for example at iteration number 70 instead of 100 Using TestStand).
Link for the product to be controlled:
https://www.thorlabs.de/Software/Motion%20Control/Kinesis/Kinesis-labview.pdf
Thank you!
01-26-2021 04:49 AM
Hey Ahmed,
I assume it's normal that the program will hang earlier while using LabVIEW and that's because there is a latency in transferring data from the lv file to the original TestStand program. It is interesting to understand here which version of LabVIEW and TestStand are you using?
