NI TestStand
TestStand Script automation by CLI or any other work around
I want to automate the process of Teststand script or sequence like by use of CLI or any work around.
can you please guide how can we make it possible.
(535 Views)
See Configuring Sequence Editor and User Interface Startup Options
https://tmesystems.net/
(516 Views)
You can automate TestStand sequences using the CLI by launching `SeqEdit.exe` with command-line arguments:
```bash
SeqEdit.exe /run MainSequence "C:\Path\To\YourSequence.seq"
 For advanced automation:
- Use Python + subprocess to trigger sequences
- Apply the SinglePass process model for proper execution
- Configure report plugins via `ResultProcessing.cfg` for automated output
 Helpful walkthrough: Automating Test Sequences with TestStand
This setup enables full automation without manual intervention.
Best Regards,
Thomas Batson
(473 Views)
Please explain what exactly you intend to do, are you looking to create and configure a Test Sequence using CLI instead of Sequence Editor?
Santhosh
Soliton Technologies
(465 Views)
