NI TestStand
TestStand MCP beta
I’m planning to release a TestStand MCP in the next days. It is almost fully functional, so the main features are already working. Is anyone interested in becoming a beta tester?
"mcpServers": {
  "teststand": {
    "command": "C:\\Projects\\TestStandMcp\\TestStandMCP.exe",
    "args": []
Best
Claude
Btw.: NI should be able to implement this using the TestStand source code within a few days. I had to implement it using API calls that aren’t particularly well documented!
CLA / CTD / LabVIEW Champion
Message 1 of 18
(3,630 Views)
How is this going to be different from NigelAI integration in TestStand?
Santhosh
Soliton Technologies
Message 2 of 18
(3,609 Views)
You can use it directly from the strongest AI tools available on the market (Anthropic Claude, GitHub Copilot ....). You can directly generate test sequences from flowcharts and so on... 🙂
Message 3 of 18
(3,591 Views)
For example you can Generate from a Picture or PlantUML or whatever Flowchart Sequences:
You can also generate Flowcharts from Sequences:
My MCP is almost complete. I'm currently working on the implementation style guide...
Message 4 of 18
(3,565 Views)
Hi, looks cool. I would be interested in checking out what it can do 🙂
Message 5 of 18
(3,403 Views)
I am currently preparing the code for an official release. I will share the link as soon as everything is ready.
Message 6 of 18
(3,392 Views)
Here is the first version of TestStand MCP Beta_V0.0.1:
https://github.com/Zuehlke/teststand-mcp
https://github.com/Zuehlke/teststand-mcp/tags
Best Claude
Message 7 of 18
(3,348 Views)
I have released Beta_V0.0.2, which includes some minor changes. This version also features a Claude agent that helps with automatically linking sub-sequences when creating sequences from flowcharts.
=> Agent is not perfect, but guides you through the subsequence calls
=> Claude Agent is only included in the Source code!
https://github.com/Zuehlke/teststand-mcp/releases/tag/Beta_V0.0.2
Message 8 of 18
(3,304 Views)
I’m currently using the MCP for my own projects and everything is working as it should. Whenever I find something, I create a new release and optimise the code so that fewer tokens are used.
=> Tokens: the currency of the future!
Best Claude
Message 9 of 18
(3,134 Views)
I’ve created a new version with lots of improvements. As far as I can tell, everything is stable and the MCP and Sequence Agent are working together as intended.
If anyone is already testing it, please update; as far as I’m concerned, this version is a release candidate.
https://github.com/Zuehlke/teststand-mcp/releases/tag/RC_V0.3.0
Best
Claude
Message 10 of 18
(2,929 Views)
