06-25-2020 03:55 AM - edited 06-25-2020 04:33 AM
I just wanted to inform you about probable bug in LabVIEW adapter which is related to timestamps.
If we have a VI with timestamp input and we call it from TestStand we might see the error (see below) if our input is an empty string.
Details:Parameter 'time in':
The Timestamp value specified does not have the expected format: mm/dd/yyyy hh:mm:ss.sss AM/PM
Error Code:-17300; Value invalid or out of range.
Location:Step 'Action' of sequence 'MainSequence' in 'TimeTest.seq'
But it appears ONLY if I use LabVIEW runtime engine.
See the attachment (set RTE in the adapter settings).
May I ask someone from NI to confirm the bug and report a CAR?
