10-28-2020 12:39 PM
I've created a Test Sequence that utilize test VIs compiled into a packed library file. The sequence works and we're getting ready for deployment the problem is that when I try to build the Deployment, the build fails because it's looking for lvanlys.dll (see the attached screenshot)
What's baffling is that lvanlys.dll is at the specified destination. Even when I include lvanlys.dll in the packed library build, the TestStand Deployment utility doesn't seem to recognize it and give the same error. Has anyone encountered this issue before?
11-30-2020 12:16 PM
Hello
Try to reinstall the labview run-time engine. Make sure matches with your labview development version.
