TestStand Building Express VI menu error 42
Trying to refresh/build express VI menu in TestStand 31 using LabVIEW 7.1.1f2. Get error code 42 (generic error). Any suggestions?
Have tried to delete "ExpressMenu7.1.1" in ..\TestStand 3.1\Cfg - same error
(2,842 Views)
I will work on a solution for this, but could you please post a screenshot of the error message?
Peter Porsman | Application Engineer | National Instruments
Peter Porsman | Applications Engineer | National Instruments
(2,813 Views)
Hi
I've found a solution: Only if default menu is selected in LabVIEW, TS is capable to update the express menu.
Best regards
Vagn
(2,809 Views)
Hi Vagn,
That's great. Thank you for the update and error description.
(2,803 Views)
