NI TestStand
TestStand Build aborted due to project libraries having duplicate names
We are building a TestStand build with multiple LabVIEW projects. The LabVIEW projects hierarchy we have maintained same, that is all the projects have the same folder and sub-folder structure.
The class names and controls for different projects too have the same name. When we are trying to generate a build, the build generation is aborted with the message "While Processing VIs...
Error: The following VIs or project libraries have duplicate names.
You must change the duplicate VI names or add the VIs to project libraries."
(2,390 Views)
Hello Venkatdelli,
Take a look at the following help documentation and try out the steps it lists:
  • Add the files with duplicate names to a LabVIEW project library.
  • Rename the files with duplicate names and use the LabVIEW rename option to update the callers automatically.
  • Configure the steps in the sequence to be called in the context of different LabVIEW projects.
Hope this helps,
(2,372 Views)
