07-01-2019 09:14 AM
I would like to reproduce the same effect that in TestStand allows with a double click to open a sequence from a Call Sequence.
In the TS Full-featured User Interface (LV version) this functionality is not present, if you click 2 times on a step, the properties window is opened and the same happens for the call sequences, but in TestStand double clicking on a Call Sequence opens the corresponding sequence to which it refers (present in the sequence file).
07-03-2019 02:48 AM
to get the effect you want you should change the TestStand user interface on LabVIEW, but it's extremely complex to do and honestly I'm not sure it's worth it.
Alessia
06-25-2020 06:26 AM
I did it, using DblClick Callback of SequenceView object.
