09-18-2008 09:08 AM
Hi all,
I'm working with TestStand 3.5 and LabVIEW 8.5 and my problem is the following:
I execute a TS sequence containing pass/fail tests, numeric limit tests and so on and at the end of the sequence I want to show a "failed tests list" containing the following data for every step that failed:
subsequence name, step name, output value/string/boolean, limit/limits or desired string or desired boolean state.
I think the sequence could be general (usable for every kind of TS sequence) and could be a SequenceFilePostResultListEntry callback that generates a string containing the above data regarding the step executed, then all the strings could be concatenated at the and of the sequence.....this is what I think
My question is....does anybody have a sequence for this purpose ? Or where could I find an example/demo/sequence that could help me ?
Thanks for your help !
09-18-2008 09:37 AM
Hey,
You can suppress Passed/Done/Skipped steps from not showing in the report by going to Configure>>Report Options and on the Contents tab choose either ASCII Text or HTML Document for the Report Format. Then check the Include Step Results and change the Result Filtering Expression to Exclude Passed/Done/Skipped. Then the report will only show failed steps.
09-18-2008 10:14 AM
Hi, thanks for your answer but you didn't understand exactly what I need:
I don't need to obtain a report (I already configured a report) but really I need to print a label containing the failed steps data I already wrote in the first message.
Then I need a string containing the failed steps names, values, limits and so on. So, I need a sequence/callback that in case of a failed step gives me his name, the limits and the result value in any case: string, number or boolean result; value of the limits; the kind of comparison.
Can you help me ?
Thanks in advance
09-18-2008 11:37 AM
Have you tried the SequenceFilePostStepFailure or ProcessModelPostStepFailure Engine Callbacks?
See page 10-6 (171) of the TestStand Reference Manual.
09-18-2008 12:06 PM
Yes, this is another idea....but anyway I should develop all the steps inside the callback.
Perhaps I'm looking for a too easier solution: a sequence already developed for this purpose, or just an example or a sequence similar to what I need.
Is there someone that already developed something useful for my problem ?
09-18-2008 02:44 PM
09-18-2008 05:29 PM
09-18-2008 05:46 PM
You do have access to the report before your sequence finishes as a big string. Basically in the ModifyReportHeader Callback you can access the report body by using RunState.Caller.Locals.ReportBody. This returns a giant string with the report body. That would be kind of a pain to parse though.
Let me know if you have any questions as this could be a tricky one. I don't promise all the answers just the ones I know or have time to look up. 🙂
09-19-2008 02:38 AM
Wow ! This is a very interesting "TestStand secret" that could help me !
I'll try to read the report data and if possible I could parse it by LabVIEW (I'm much more skilled with LV than TS): this is good also because at the end of the failed steps data string creation I have to print a label using a LV vi.
Thanks a lot !
