09-21-2026 02:28 AM
Hi.
Last week I installed TestStand 2026 Q3 (32-bit) on a VM for the first time, and I can't help noticing that the startup time for the sequence editor is extremely slow compared to TestStand 2024 Q4 (32-bit), which is the version I have been working with for a while. At the first start after boot the time from I press the short cut in the start menu and until the UI is loaded and ready for use its around 50 seconds. That is crazy slow in my opinion. If I then close the sequence editor and open it again a few seconds after the complete startup time is about 30 seconds, which I still find to be slow.
The sequence editor for my TestStand 2024 Q4 is ready after about 30 seconds at first start boot. Startup after that is abort 12 seconds.
I suspect one difference is that in 2026 Q3 it has to login to my NI account to connect to Nigle.
I have not had a chance to work with any of the 2025 versions.
So I wanted to ask if anyone else has that experience as well, or if it just me. I would like to state that all my work with TestStand 2024 Q4 is also done in a Windows 11 VM on VMWare. Both VM's are clones of the same Windows 11 images.
09-21-2026 01:15 PM
Not sure if this could be contributing, but I have seen other non-NI applications load slower when they transitioned from .NET Framework to .NET Core, and TestStand did this starting with TestStand 2025 Q3. I am still on older versions of TestStand, so I have not seen this yet.
09-22-2026 09:14 AM
09-23-2026 08:57 AM
One detail that may help isolate the version boundary: NI’s release history lists the Sequence Editor’s .NET 8 migration under 2025 Q2. That gives a version to compare, but doesn’t establish that .NET is responsible for the delay.
I’d measure launch-to-ready with no sequence loaded separately from the step-selection delay PBRT describes. Using the cloned VMs, a small table of exact TestStand build, cold/warm launch time and whether any sequence was opened would make the comparison clearer. Then repeat the step-selection measurement with Step Settings visible and hidden. Does the launch slowdown remain with no sequence loaded?
Reference: https://www.ni.com/docs/en-US/bundle/teststand/page/new-features-and-changes.html
I haven’t reproduced the issue locally.
