NI TestStand
TestStand 2019 does not show "IVI Switch Step" on insertion palette
I am new to the TestStand, and I try to use a NI switch module in our test. After reading the following link:
https://www.ni.com/en-us/support/documentation/supplemental/09/using-switches-in-ni-teststand.html, I know that there are several ways to integrate NI switch module into TestStand.
But I find that there is no "IVI Switch Step" on insertion palette of TestStand 2019. I can not try "IVI switch step" approach. Is there something missing?
Thanks for your help
Godel
(1,079 Views)
Accepted by topic author godel
The IVI step types are only supported by 32-bit TestStand and are no longer installed by default. You can install them following the instructions here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015CU2SAM&l=en-US
https://www.linkedin.com/in/trentweaver
(1,048 Views)
