NI TestStand
TestSTAND guidline
I've been doing TestStand for about a year now, but never really followed specific coding rules. Wanting to go further, will you have a link of page offering rules for writing sequences in TestSTAND?
Containing for example :
- Ways to name variables
- How to organize sequences
(2,580 Views)
Accepted by taoufiksmires
Here you go
https://www.ni.com/en-us/support/documentation/supplemental/09/teststand-code-module-development-bes...
https://www.ni.com/en-us/support/documentation/supplemental/08/teststand-type-management-best-practi...
BTW, it is TestStand and not TestSTAND like LabVIEW
Santhosh
Soliton Technologies
(2,569 Views)
Merci beaucoup, ça va m'être bien utile !
(2,530 Views)
Can you help me?
When I open Teststand 2020,it will tell me the following error:
The TestStand Service may not be running. The TestStand Engine uses this service to ensure that external environments such as LabVIEW, LabWindows/CVI, and Microsoft Visual Studio are properly updated. If you just installed TestStand, ensure that you restart the system before using TestStand.The TestStand Service can sometimes be delayed after restarting a system if a previous service is slow to start. For example, the Windows Workstation service can delay for a few minutes on startup when trving to reconnect to mapped network drives if the drives are not immediately available.Determine the offending service and see if you can resolve why it is slow to start. An option is to mark the service as manual, and delay the launching of it by adding a command to the startup group to start the service.
Please help me how to solve this problem.
(2,412 Views)
