NI TestStand
Test UUTs report options callback
I am using the 'Test UUTs' entry point to test many units in sequence using the sequence model. However each of the test results get put into the same report; how can I get the results to go into seperate files for each unit. Is there an option for this or do I need a callback? Maybe I could use the 'single pass' entry point in some sort of loop, what is easiest?
TestStand 2010
(4,835 Views)
Use the checkbox here (Configure»Result Processing..😞
Hope this helps,
Trent
https://www.linkedin.com/in/trentweaver
(4,825 Views)
It seems I dont have that option when specifying the file path by expression; why is this? How can I still have the 'New UUT Report file for each UUT' option and specify the report file path within the sequence by expression?
(4,757 Views)
Check the TestStand Help: Specifying Report File Paths by Expression topic.
$(UUT)—Replaces the macro with the UUT serial number. This macro creates new UUT report files for each UUT.
-Trent
(4,748 Views)
Thank you.
(4,734 Views)
