NI TestStand
-TesStand - On PreLoad - Multiple instances of nimxsoffline.exe opened?
nimxsoffline.exe - On TestStand Preload - multiple instances are opened and stay open unless Modules are unloaded (2013 & 2012SP1)
It is Workspace dependant and happens on a TestStand Preload.
All Code Modules are Labview and there are Project specific StepTypes.
Has anyone seen this before ?
(4,585 Views)
Hi Teuch,
Thank you for your question. It is absolutely fine that nimxsoffline.exe since it is required for
a TestStand to work properly.
It is a system service and it should not cause you any problems.
Kind Regards,
(4,547 Views)
