NI TestStand
Terminating Non-Reentrant vi:s in TestStand using the TerminateAll function
Hello!
What does the Terminate All function in TS do (The one under debug)?
I have some problems with the Terminate All function and non-reentrant vi:s, explained below. See attached files for a simple example of my problem.
I wanted to have a vi non-reentrant but encountered a problem with the built in Terminate All function.
When I run the same vi in three threads, one thread executes the vi while the other two wait for it to complete (as expected with non-reentrant). When I Terminate the execution however, only one (or two) of the three threads are terminated, while the other(s) are stuck (Note: I use TS Termination monitor to exit the vi) .
I have attached a simple example where I have a simple vi with a while loop, waiting for TS termination.  The Sequence file is set to use ParallelModel.Seq as Model. If I use the Models built in termination everything is terminated as expected (It terminates every thread separately). However if I use TS debug "Terminate All" only 1-2 of the threads are terminated.
Thanks in advance.
(2,323 Views)
Accepted by topic author Joel_V
I tried your code. By getting the executions states before starting the termination monitor, I see for 2ond and 3rd VI call that termState is ExecTermState_Terminating (GetStates method). So if different of ExecTermState_Normal, you can choose not to call the Termination monitor and associated loop.
Hope this helps,
(2,268 Views)
Works like a charm.
Implemented it inside the loop in my other vi:s and they stop as expected. Smiley Happy
I find it weird that Execution termination state is terminating but termination monitor return false, but your had a simple solution to that.
Thanks a lot!
(2,218 Views)
