NI TestStand
TS2023 32bit installation distroys existing TS2019 32bit
After installing TS2023 32 bit I can't use TS 2019 32 bit because of such errors even after TS2023 uninstall:
(177 Views)
Nothing helps, I have uninstalled all TestStand versions and installed just 2019 still same errors appears for all the steps.
(144 Views)
Looks like a dependency dll was replaced with a higher version and hence causing the TS2019 to break.
Santhosh
Soliton Technologies
(141 Views)
Accepted by topic author csgyorgy
Issue solved. The error came not from 2023 installation but because I've set in "Search Directories" a folder which contained a 2023 TestStand dlls. SeqEdit.exe during dependencies load found these 2023 dlls and loaded instead of 2019 version dlls.
(136 Views)
