09-14-2018 04:55 AM
I have an array of struct containing data in the CVI fucntion. I need to get a copy of these data from the CVI function.
Did any one have an example of this ?
Thanks in advance,
09-17-2018 02:59 PM
I think the following article from our website will be helpful to what you are looking to do: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJ23SAE.
09-24-2018 04:19 AM
Thank you MChanchu for your reply.
I solved the problem by adding code on my CVI dll, I used the TestStand API functions to update data array.
