NI TestStand
TS2013: Storing Additional Information for UUTs and Test Stations in Process Models
As discribed in TestStand 2013 Helpfile, storing Additional UUT Data is a new feature. It would be very helpful, but I can't get it into reports.
I used the following code:
RunState.Root.Locals.NewSubProperty("UUT.AdditionalData.SW_Version_Inverter",PropValType_String,False,"",0),
RunState.Root.Locals.UUT.AdditionalData.SW_Version_Inverter = "B123"
This is working fine, the property is added correctly. Now I use the description from the helpfile:
"To specify that all subproperties automatically appear in a report, set the IncludeInReport property flag on the AdditionalData property."
I do this that way:
RunState.Root.Locals.SetFlags("UUT.AdditionalData",0,0x2000)
 But if I do this, the report generation freezes and I don't get any report. What did I wrong?
(4,511 Views)
Accepted by topic author Ludwig72
attached a working sequence file,
best Regards Fabian
(4,407 Views)
Thank you Fabian for your advice to try it with a completely new sequence. Not the code was wrong but the type definitions in my project.
The mistake was, that I used a PreUUT callback which was developed with an old TestStand Version. The callback defines the UUT types as a parameter set and seems to be not compatible with the new TS2013 type definition that is extended by AdditionalData.
After setting up a new project with clean callbacks everything is working now.
Best regards Ludwig.
(4,401 Views)
