07-13-2012 03:34 AM
i am using TS4.2.1 and LV8.6 in WIndowsXP. There i use the default TS-OPUI.
In the TS-OPUI there is in the left side a Execution-list with a final-result Passed/Failed and a color green/red.
When i click on a execution then it shows me on the right side the report of this execution.
Now i have the problem that TS shows a final result of PASSED but there are some fail-tests in the sequence that are shown in the report.
How is this possible?
07-13-2012 03:54 AM
07-13-2012 04:03 AM
None of my steps has this flag disabled 😞
I saw in the reports that all "wrong" results also have an "ERROR"-step inside.
Is it possible that the error overwrites the normal result (which should be fail) with passed?
07-13-2012 05:30 AM
That is possbile
Just visit this old thread:
http://forums.ni.com/t5/NI-TestStand/Force-TestStand-Step-to-Fail-When-Error-Occurs/m-p/435510
regards
Juergen
07-13-2012 05:53 AM
Now i created a dummy sequence that contains dummy-labview-vis (one is pass, one fail, one error)
When running the sequence then the report says "Fail" but the Icon in Teststand shows a green Passed-Icon.
Does someone know which variable sets this final-icon in the Execution-list?
(In the model the Main-sequence-callback finished correct with "error".)
Thx
07-13-2012 06:52 AM
I am getting nearer...
When the error occurs then Teststand shows me the RunTimeError-occured-popup (screenshot).
When selecting here: runCleanup -> then the result goes on Pass
When selecting here: ignore -> then the result goes on Fail.
I am sure that it is somewhere in the model.
Because when using the default-model (and not my custom model as above) then the result is going correct on Error when selecting runCleanup.
The question is nonly: Where is this set?
07-13-2012 07:19 AM
I fouond the missing line:
